nivea extreme comfort shaving gel
Well i use gel from Lidl....shave my head and face....its just shaving gel ffs.
About as spot on as saying 'What are you doing buying expensive wine! it all tastes the same' :p
Gillette always gives me the best 'non irritating shave'
If I am honest (and in before gay) the skin on my face is pretty sensitive. If I don't use good razors / gel I tend to get bumps or ingrowing facial hair which sucks. :(
Good god man, why would you use any kind of gel? Its the shaving equivalent of junk food.
For the absolute win.
In shaving newer is not always better. The old style soaps and creams are still the best way to go. Applied with a badger hair brush for best results.
At the moment I am using Taylor of Old Bond Streets Almond shaving cream. Lovely stuff.
I use shaving soap.. I bought a block over a year ago for £6 and it's still only about 1/4 used, and probably miles better :p.
Yeah, I mix between the Trumper's Rose and Proraso. It's substantially better and cheaper over the course of its life than all the gunk in a can the supermarket's sell.
@ Busa : what's happening is that more males are realising that the crap that Gillete and Nivea sell is overpriced and underspecced for decent shaving. If you want to use cheap stuff and it works for you, good on you. Seriously, that's great. Don't knock those who know there is better, more affordable ways of getting the same end result. If you tried it - which I'm sure you won't - you'd see what I mean on your first shave.
