nivea extreme comfort shaving gel
19 Feb 2008
Home
nivea extreme comfort shaving gel.
£5.37 each or 2 for £4.00 from the uk's number 1 supermarket.
12 May 2005
I use King of Shaves.... it's awesome I am telling you.
Which reminds me I need to get some. Might check this out though if you recommend it highly?
OP
19 Feb 2008
Home
just had a shave and i must say it is lovely to shave with.
and it smell's divine afterwards.
1 Dec 2007
Well i use gel from Lidl....shave my head and face....its just shaving gel ffs.
18 Aug 2005
Shropshire
About as spot on as saying 'What are you doing buying expensive wine! it all tastes the same' :p
Gillette always gives me the best 'non irritating shave'
12 May 2005
If I am honest (and in before gay) the skin on my face is pretty sensitive. If I don't use good razors / gel I tend to get bumps or ingrowing facial hair which sucks. :(
24 Nov 2002
38.744281°N 104.846806°W
For the absolute win.
19 May 2005
Scottish Borders
In shaving newer is not always better. The old style soaps and creams are still the best way to go. Applied with a badger hair brush for best results.
At the moment I am using Taylor of Old Bond Streets Almond shaving cream. Lovely stuff.
Pho
Pho
18 Oct 2002
Derbyshire
I use shaving soap.. I bought a block over a year ago for £6 and it's still only about 1/4 used, and probably miles better :p.
Caporegime
29 Aug 2007
Auckland
Yeah, I mix between the Trumper's Rose and Proraso. It's substantially better and cheaper over the course of its life than all the gunk in a can the supermarket's sell.
@ Busa : what's happening is that more males are realising that the crap that Gillete and Nivea sell is overpriced and underspecced for decent shaving. If you want to use cheap stuff and it works for you, good on you. Seriously, that's great. Don't knock those who know there is better, more affordable ways of getting the same end result. If you tried it - which I'm sure you won't - you'd see what I mean on your first shave.
