- 25 Sep 2005
An interesting item I came acros today. Sounds good but whether the tech can be created for PCs is another story.
Yahoo
Yahoo
So in short typical marketing hype/snake oil which should trigger BS-filter of everyone thinking logically.As said they have a fan in the bottom and also the reviews say they are much noisier than a normal fan as well as not pushing as much air.
Failure.
It IS a bladed fan.
It uses a hidden impeller out of view and out of the main airflow path. That then produces "high" pressure air which is directed out in a ring shape around the circular "fan" section.
Through fairly well known principles the high speed air drops in pressure as it exits but pulls along even more air from the environment as it does so, thus generating flow which didn't pass through the fan at all.
Interesting mind you.
Small high pressure fan
