WTF.....Just found out normal USB cables don't fit this N96 16GB![]()
No...I thought the n96 would have used the same normal USB mini connector as my old n95 8GB used.........What kind of phone uses full size USB cables o.0
When the He** did micro USB cables come out??? It fits micro USB cables..
All my stuff have always used mini USB connectors...
Wonder if they use the same micro USB standard for all digital camera's / ipods etc one day...micro USB is the new standard for EU mobiles.
http://en.wikipedia.org/wiki/Universal_Serial_Bus said:The newer Micro-USB receptacles are designed to allow up to 10,000 cycles of insertion and removal between the receptacle and plug, compared to 500 for the standard USB and Mini-USB receptacle. This is accomplished by adding a locking device and by moving the leaf-spring connector from the jack to the plug, so that the most-stressed part is on the cable side of the connection. This change was made so that the connector on the (inexpensive) cable would bear the most wear instead of the micro-USB device.
