The newer Micro-USB receptacles are designed to allow up to 10,000 cycles of insertion and removal between the receptacle and plug, compared to 500 for the standard USB and Mini-USB receptacle. This is accomplished by adding a locking device and by moving the leaf-spring connector from the jack to the plug, so that the most-stressed part is on the cable side of the connection. This change was made so that the connector on the (inexpensive) cable would bear the most wear instead of the micro-USB device.
