I presume that doesn't spin them down if they're being used/accessed/written too? You never know with WindowsYou can tell WHS in the power options in control panel to turn off the hard-drives after x minutes. Only issue I came across with this is a delay when the HDD spins back up.
.I presume that doesn't spin them down if they're being used/accessed/written too? You never know with Windows.
Anyone using utorrent succesfully? I'm having a few issues.
Firstly, 'Auto-loading torrents from directory' doesn't seem to work.
Secondly I've set my folders to '\\server\Downloads' and '\\server\Downloads\torrents\' respectively - I downloaded mint linux torrent last night and whilst the torrent started under supervision, it appears to have finished and deleted whilst not being supervised .
Am I just unlucky this one time or have I missed something obvious?
....Even then you cannot control which drive the WHS uses to store data. I think Since PP2 WHS fills the HDD one by one so this is sort of implemented already
Folder duplication is all down to a /switch mate. You either select it or not for the share you create on your WHS. Obviously if you don't select it, you have no data redundancy. Its totally the choice of the end user whether to use it or not.If WHS starts duplicating files, because it assumes it's sitting on unreliable drives, then I'm going to end up with four copies of everything.
 thats why. all 4 drives are jbod drives.
