Where do you get the toolbar thing from at the top of your screen???
Haydz - I don't suppose you have a link to the wallpaper do you please?
www.blirk.netOh go on then.
*Monkeytosh Desk*
I'll let you off if you tell me where I can get a decent sized (1920x1200 or 1080) version of that TypeR Wallpaper!!..![]()
nope, no volume control. i have no need for it. plus there just isn't room for it in my layout.
as for the taskbar controls, it's probably because you have it minimised to the notification area. look in the "columns ui" preferences and you can turn that off.
Thanks!Hi, what is the gadget you're using for recycle bin the bottom corner of your Netbook?Thanks!
Hmm, cant seem to see which option I need. This foorbar can be proper customised to the max having a quick look at some of the settings! Most of which dont mean much to me mind![]()
$drawtextex([%date% | ]%el_item_count% track$ifgreater(%el_item_count%,1,s,) | %el_sum_length%,10,25,$sub(%el_width%,40),%el_height%,%col1%,end_ellipsis)
