I'd get that voltage down if you can though, even a B3 should be able to do 3 on less than that unless it's an absolute ******* of a chip.
My 3.4GHz Q6600 1.28v is idling at 49/46/43/46 under a Tuniq Tower low fan speed.
Put the P5k-E in today, got it running at 400x9 = 3.6ghz, at 1.45v, seems to be prime stable but temps are too high (73-75) - I lapped the cooler and I've still got a 6-7'c discrepency between the cores, which is really annoying. Two are at 73-75 but the other two are at ~68, which would be fine.
 like I said before as soon as you get a board that can really push a 65nm quad you soon run into temp issues with air cooling
wish i could run my q6600 at 3.0ghz atleast , anything over 2.70 and my sound crackles and suddenly drops then comes back
