*** Official Call of Duty: Modern Warfare 2 Thread ***
Hope this makes sense -
Question: Once you get a killstreak and you use a Killstreak bonus, do the kills you get from using the bonus stack onto the “total kill streak” ?
Or do you use your Killstreak bonus wisely and take a gamble and wait to get more kills in for better reward?
Got to play some MP today! Up to lvl 10 and in the top 800,000 :eek:
This is the first COD i have owned though and my first console shooter, so i think it`ll take a while to adapt. Really enjoying it though, running well!
Not sure, but they all stack. So if you get 5 kills, you could get a bonus at 3,4 and 5 kills and then use all 3 back-to-back. Or you could have used a bonus at 3 kills, then get one more to get the next one. It doesn't take away kills to use a bonus.
from what i understand it adds on to your killstreak, but once you use 3 kill streaks thats it, i dont think you can use more than three, dont know if that helps
Anyone considering playing on Hardened straight off I would recommend going straight to Veteran as its not really that much harder and it is satisfying when you do finish the game. :)
If only I saw that earlier. went through the first run on Hardened thinking it was going to be a giant middle finger in your face like WAW. Took about 6 hours to clear it, now for the Veteran run :)
Cheers guys.
So - you keep your killstreak bonus even if you die. Say you died on 4, once you respawn you can use it?
yeah, its best practice (at least in cod4) to keep killstreak rewards until after you die, as any kills you get from them add towards your next killstreak.
True, but on the other hand, you have already got a killstreak together in order to get them, so you have a good basis to add the reward to, to try and get it even higher. If that makes sense :p depends on the situation really.
Quick question:
Does the emergency airdrop, ever drop a tactical nuke?
im wondering whether to unlock the Emergency Airdrop, Stealth Bomber, or Pavelow
