- 13 Jan 2004
- Leicestershire
*sulks* thought this was a bike thread and was going to indulge in some of my pub 'i'm a god at bikes and can do it standing up etc' banter. lol
Because it is fun...
Also since when was a "DRAG strip" used for drifting. Go away and get a clue.
I'd say it's a power problem mostly for him.
I could happily kick the rear out on the e36, come up to a corner too fast, dump a gear, turn in, hard, power on, correct steering.
Done it on 90's on on 180 corners too.
The e36 though is well designed for it, it's smooth, progressive and easy to sort.
Nobody would ever do that in a 200SX...![]()
caboosemoose said:LSD was available on the 325. It was also fitted to early 328i Sports, but replaced with traction control some time in 96. If you're looking at a Sport that has TC, then it does NOT have an LSD. An LSD was not available as an option on non-Sport 328s.
I think jacking up a rear wheel is the easiest way to know what you are getting. LSDs are pretty rare on the E36.
If you can't get a RWD car to drift even around a roundabout in the wet then you fail at driving. I'm by no means an amazing driver and I'm not claiming to be, but even I've managed a power slide in a front wheel drive car, in the wet, around a roundabout.
Did your 328 have an LSD?
iirc invader's 328 wasn't a sport so wouldnt have had an lsd?
Having an lsd isnt the be all and end all of having a slide about, just makes it much easier to maintain the slide, than an open diff.
Its about that time of year again
oow, I want an lsd!
[TW]Fox;15302487 said:The reason its hard in yours is because it's massively overtyred (Most BMW's are) really, although the lack of power doesn't help.
I like the roundabout going backwards bit, that must have taken ages to perfect....oow, I want an lsd!
