It was quite a long time ago that I used it, but I remember being annoyed enough to abandon it.I've never had a problem with 1Password being buggy, not a single issue.
 - I have used 1password for a while but am currently using the v3 beta (although, i would recommend not using this yet, its far too buggy)...really?What bugs have yo found with v3? I've not run into any problems yet.
Panzer
I'm able add them in 1Password 3.• can't add secure notes
I don't understand what you mean by this but it is recommended to upgrade to Agile's own keychain.• keeps loosing the keychain and you have to re-add it
Have not experienced this ever since using 1Password.• has closed a couple of times on its own
Not surprising since it's a beta applicationa few more too, think it just needs a couple more weeks...
It seems the feature has not been implemented yet and you could visit Agile Web Solution's forums to request for this feature to be implemented back in.btw: any idea how to change the 1P logo in safari? i like the keyhole look![]()
Yeah i did mean "Keychain Access"- I have used 1password for a while but am currently using the v3 beta (although, i would recommend not using this yet, its far too buggy)..
tell me about itWell, it seems you have a lot of bad luck with applications in Mac OS X judging from your past threads on here![]()
Basically, you're stuffed...I've installed 1Password for my father so he can just click-and-go without having to remember different passwords, but I didn't really test it enough to decide if I should install it. Apologies if it's a noob question.
