Usually the same as you would any other game. You may have to point the mod installer to your steamapps folder, or manually place files if it's that kind of install.
Ahaa! Steamapps folder is the one I needed to look in.
Cheers bud.
-snip-
I have the Shale bug. Talk to Shale and it teleports you off the map and you can't select anything.
Gah managed to find a save that is not affected. Three hours gameplay lost...![]()
This happened to me, but I got my bearings from the map and managed to walk through the walls into the nearest tunnel. I'm not sure if it was more luck than judgement, but it meant I could carry on playng rather than loading an earlier save.
It wasnt even that I had just started to use Shale as a tank and all the abilities were not working. No point in having a tank with no abilities so I went back to the save with Alistair in my party... Just as I arrivied in the dwarf city...
Come on Bioware any chance of a fix I say.![]()
Just a little heads up for people thinking of buying Dragon Age. It's available on Steam with a 25% discount for today (thursday) only.
Makes the answer to my above question all the more eagerly anticipated !!!!!!
Mods - there are already a huge amount of mods available through the Bioware Social Website and I'm trying a couple out as we speak, so there's even more scope to the game after your first run.
To briefly answer your question.
If you like RPGs and liked The Witcher and the like then you will love this. It has a great story and and you make a team of four players in your group rather than go it alone. The combat, on medium difficulty at least, is fairly difficult and very tactics based. You will probably die multiple times on certain battles before you find the perfect strategy and this is one thing which I like because winning a battle means so much more this way.
Right then ... it's similar to Baldurs Gate and NWN in gameplay, but is not based on D&D ruleset so there's a completely different set of playable character roles, skills and spells. It's party based with up to 4 characters at a time from a total of maybe 8 or 9?
Story line - it's the usual good v evil plot but it's really well written and voice acted. There are 4 major quests that need to be completed before going on to the final quest, but these can be done in any order. There are, of course, a shed load of side quests that you can choose to undertake or completely ignore.
Personally, I absolutely love the game. I play it mainly through the tactical view, but have found that I use the 3rd person view more than I thought I would. This is mainly when expoloring as the tactical view has the disadvantage of not showing much that's ahead of you. I'm currently 60 game hours in and am on the 4th quest before moving on to the end quests. This game is a amazing for value for money, particularly if you get the Steam discount.
To sum up ... BUY IT!![]()
Any good ones?
Can anyone recommend any decent mods to add to the second play through. I think I have found new Morrigan and Leliana face mods as I like the concept art more than the final models.![]()
Is it better to get the standard edition of this or the digital deluxe one ?
