Car Insurance
I agree a premium should be higher for a set of alloys, but age relating alloy wheels is a bit of a joke tbh.
Alloy wheels are going to have a negligible effect on performance. The only real increased risk is the increased desirability to thieves.
The risk of them getting stolen is so small as to probably have no effect on premiums. It's all down to the fact that those who do this and are young tend to make more frequent/expensive claims.
No, alloy wheels are nothing like an air filter or dump valve insurance wise. Aftermarket Air filter/Dump Valve = Performance enhancing. As far as an insurance company is concerned, you have improved the car's performance specifications than standard, as a result it is quicker and you are money likely to have an accident (or so they say).
The premiums are loaded for completely different reasons, so how exactly are they the same?
An air filter makes no real difference to the performance of your car. It does, however, tell an insurance company what sort of person you are LIKELY to be.
Alloy wheels do the same thing.
Yes, it sucks, but thats how it is.
There's very little point suggesting companies like More than, elephant, swiftcover et al in these threads - they're all on comparison sites.
Comparison sites are a bit crap, mostly because a lot of companies arent in included, but if one of the companies who participate in them was going to give a decent quote the OP would have found it by now
Very true really, sad, but hey ho! :p
Gone with Elephant for the time being, cheapest one i could find that would insure me...Without searching around for days on end.
End of the day I've dropped it by £150 :)
Thanks for the input all
If they are factory fitted, then no need to tell them because your car is original spec. Even if your car is a special edition that came with alloys, thats still the spec put out for that edition
They are factory fitted upgrades :). The stock ones are 16" but I'm on 17" :).
But I don't live on these forums to witness all the threads coming in and out every day :)
recently the mods added a new thing to the forum, think its called 'search'. Guess it must be rubbish though if you needed to start a new thread ;)
The size of the wheel means nothing, if its the way the car rolled out of the factory then its not a mod and you dont have to delare it, if they ask "do you have alloy wheels fitted?" you can say yes but be clear about the fact they are an original part of the car and not something added by yourself or a previous owner.
If you just said yes then it could have been assumed by the person at the other end of the line that you modified the car and will either have paid more for your insurance than you should have or been denied a quote
If its a problem that this is a frequently asked question, perhaps there should be an FAQ post stickied to the top of the forum to stop people asking it.
You're wrong. It's not a mod as such but technically any options over base spec should be declared.
You couldn't be more wrong mate.
Swiftcover were circa £500 cheaper than my previous insurer, and over £200 cheaper than anyone else I could find.....including when using the comparison sites.
Comparison sites are a load of crap, most people are too dumb to reconise them for what they really are which is insurance brokers, just like any other insurance broker they dont need to give you the cheapest quote and quite often they dont. They earn percentage commision on the sale and the higher the premium the more commision they get. You can and will get cheaper insurance by going direct with an insurer
The very reason a broker/comparison site asks what your best quote has been is because if your best was £600, and their best is £300 they could quite happily give you a quote for a company that is £550 knowing you would be happy and they get more comission, they are business, do not assume they have your best interest to heart
So you use a comparison site to find which are the lowest prices, then go to their own websites or phone them directly.
I think you're wrong on this one matey.
Insurers only want to know if the car has been modified/altered from the state it was in when it left the factory.
Directline and the other RBS group ones certainly required info on changes from the standard spec when I worked there a few years ago. For normal options it very rarely made any difference to the cost though. It's perfectly logical as a base spec model can cost many thousands less than a specced up model.
It is, but the owner who bought his car second hand can't reasonably be expected to know what equipment his car had fitted as optional extras can he?
