Alloy wheels are going to have a negligible effect on performance. The only real increased risk is the increased desirability to thieves.
No, alloy wheels are nothing like an air filter or dump valve insurance wise. Aftermarket Air filter/Dump Valve = Performance enhancing. As far as an insurance company is concerned, you have improved the car's performance specifications than standard, as a result it is quicker and you are money likely to have an accident (or so they say).
The premiums are loaded for completely different reasons, so how exactly are they the same?
[TW]Fox;15416212 said:An air filter makes no real difference to the performance of your car. It does, however, tell an insurance company what sort of person you are LIKELY to be.
Alloy wheels do the same thing.
Yes, it sucks, but thats how it is.
If they are factory fitted, then no need to tell them because your car is original spec. Even if your car is a special edition that came with alloys, thats still the spec put out for that edition
. The stock ones are 16" but I'm on 17"
.But I don't live on these forums to witness all the threads coming in and out every day![]()
They are factory fitted upgrades. The stock ones are 16" but I'm on 17"
recently the mods added a new thing to the forum, think its called 'search'. Guess it must be rubbish though if you needed to start a new thread![]()
The size of the wheel means nothing, if its the way the car rolled out of the factory then its not a mod and you dont have to delare it, if they ask "do you have alloy wheels fitted?" you can say yes but be clear about the fact they are an original part of the car and not something added by yourself or a previous owner.
There's very little point suggesting companies like More than, elephant, swiftcover et al in these threads - they're all on comparison sites.
You're wrong. It's not a mod as such but technically any options over base spec should be declared.
Comparison sites are a load of crap, most people are too dumb to reconise them for what they really are which is insurance brokers, just like any other insurance broker they dont need to give you the cheapest quote and quite often they dont. They earn percentage commision on the sale and the higher the premium the more commision they get. You can and will get cheaper insurance by going direct with an insurer
The very reason a broker/comparison site asks what your best quote has been is because if your best was £600, and their best is £300 they could quite happily give you a quote for a company that is £550 knowing you would be happy and they get more comission, they are business, do not assume they have your best interest to heart
I think you're wrong on this one matey.
Insurers only want to know if the car has been modified/altered from the state it was in when it left the factory.
Directline and the other RBS group ones certainly required info on changes from the standard spec when I worked there a few years ago. For normal options it very rarely made any difference to the cost though. It's perfectly logical as a base spec model can cost many thousands less than a specced up model.
