How does Climate Control affect MPG?
Couldn't tell you if it affects MPG as I've not had it off long enough to notice.
05 Mondeo Zetec 2.0 Oil Burner.
"Yeah that!" :D
Mine's an 04 plate though.
Don't notice when it kicks the compressor in either, whereas on my mk 1 Mondeo V6, the compressor would come in with a clunk, and it noticeably sapped power.
[TW]Fox;15427181 said:
Big as in big. A 1.4 litre engine is not big. 2.5+.
With my Scania (12 Litre in-line 6) the difference is under 0.5 MPG. (Totally un-scientific, merely what I have deduced playing around with my Aircon & fuel computer!)
Mine is 2litres only yet CC+AC is on every time and with it off MPG doesn't shift much at all.
What does make my MPG go from 39 to 24 however is damn traffic and my lack of a desire to eco-drive much these days ¬_¬
I don't think it makes a blind bit of difference in my 1.6 Turbo.
Mine is on most of the time, even in the winter (helps keep the windows clear), however, it was broken for a few weeks at the end of the summer, I noticed no real difference in fuel economy. I'd be surprised if it makes much more than 1MPG difference on my car.
Very surprised that it makes anything like as much difference as that, what does 0.5mpg represent in terms of total %'age on a tractor like that? Must be a fair bit? :)
I thought the main factor was whether the compressor was belt driven or the more eco electric compressor version, in the same way that cooling fans were originally belt driven the electric radiator fan improved engine efficiency considerably
Usually even a belt driven compressor will have a clutch to engage and disengage it. I could see how if it was engaged perminently this would be the case but otherwise? :confused:
An electric compressor makes little or no drag on the engine - only the battery, no clutch required either so it's got to be the better option
Depends on the efficiency of both systems, an electic compressor will simply but more load on the alternator which in turn puts more load on the engine.
An electric compressor will have a fairly meaty power draw though putting excess load onto the alternator, i cannot see it really being much different?
I've never understood that part about the alternator affecting the engine efficiency with extra load as it's constantly belt driven anyway
My understanding is a larger electrical load on the alternator means a bigger force trying to stop the alternator from spinning, so the engine is required to put more physical power into the alternator to stop it from stalling under the electrical load demand.
But i'm happy to be corrected if this is wrong.
