Hey gamesaregood, thanks for the heads up on these!
I'm just working out if I have enough spare time to test one of these as well as a Sempron 140 (Sargas Die) and I'm still only about half way through testing a Athlon II X3 425 heh!
Couple of things I'm wondering, if the chip has a max multi of x11 your gonna be needing a 300MHz-HT link to get the chip to 3.3GHz, I'm not sure how easy it is to get the Ht-Link that high?
Also on the product
link you posted above these are sold as Athlon chips (not Athlon II), I'm not sure what the main differences between Athlon and Athlon II are?
. . . . Is it just a product name or are there big underlying architectural differences?
From your CPU-z screenie it does look just like a full blown
Deneb die? perhaps with a faulty DDR3 memory controller?
I may have to choose just one new chip to test out of this and the Sempron 140, either choice isn't that good if they don't unlock . . . although probably the AMD Athlon™ X2 5000+ at least offers a guaranteed dual core whereas if the Sempron doesn't unlock your stuck with a mono core!
Lot's of nice cheap chips though, look foward to any updated results you have!
