- 6 Dec 2007
Does the factory HU have preouts?
Hah i know people running more than 550wRMS through their tweeters for SQ, gain very low ofcourse.
A car is a very different sound environment to a house and you need to seriously overcompensate due to road noise and NVH.
True but there is still no way you 'need' 550 watts.A car is a very different sound environment to a house and you need to seriously overcompensate due to road noise and NVH.
Are you sure about that?![]()
It won't be 550 watts RMS @ anywhere near 4 ohms anyway, that would be mega ££!With 550RMS it'll be much louder than a nightclub.
.Does the factory HU have preouts?
This is the major point, if the HU doesn't have a preout, you aint putting anything in there other than the front speakers
And anyway as Clarkey said, even if you want nighclub volumes in your car (remember the cabin is small compared to your average room) you wouldn't need so much power.
are you refering to the band or the sound quality
either way, yes.![]()
Incidental to the OP as he has a capable head unit, but it's not the major point, as you do not need preouts to amplify a head unit signal.
I have 800wrms at 4 ohms for £75 :S
yeah, thats all well and good if you leave the treble and bass controlls flat off. otherwise your sub will recieve the same bloated, probably usless below 20hz, signal the the headunit is driving the speakers with.
id rather a new headunit with a preout than bodging it with a high level signal.
but then you'd have to spend £200 instead of £20. I'd rather have a Ferrari than a Fiat - and? Of course, anyone would rather have a new head unit than a line converterbut then you'd have to spend £200 instead of £20. I'd rather have a Ferrari than a Fiat - and?
Anyway I was not debating the pros and cons of converters vs. pre-outs, but merely pointing out to Liquidfox that he was wrong when he said that pre-outs are required to amplify a head unit signal. I even said it was incidental to the OP's scenario in the hope of avoiding exactly this disparate discussion, but alas to no avail.
