If you're spending that much money on graphics then you already have a proper case, if not then you are a noob with a fat wallet and haven't done any research.
How do you come to this conclusion??
they could just as easily be A2 silicon versions running at those clocks and they are undervolted and running very cool, those clocks might even be well under the expected final clocks. unfortunatly its all guesswork, all we can say reasonably accurately is that they do seem to have working versions.
Yes, shift the blame, because ATI can do no wrong.
Well tbh all I really care about is a price war as even the last generation cards are capable of any game today barring DX11 features.
It won't unfortunately, if the HD5970 spanks the Fermi and costs the same I'm not sure where the price war will come into it. If the current rumours of the specs for a 360gtx are to be believed, it will still cost the same to make a huge and expensive core but won't be ahead of a 5870.
Our best hope for a price war is a competitive product to the 5770. IF Nvidia can release a lower end Fermi with reduced mem bus, shaders, pcb layers and is actually decent performance at £120-150, then AMD might have to drop the 5770 to £100 and they'd HAVE to either introduce something inbetween the 5770 or drop the price on the 5850, either way its good for us.
"Snip"
From the specs and being conservative on the estimation the 360 _should_ be 10-15% faster than the 5870 - and possibly 20% faster with very good drivers. The 380GTX doesn't look like besting the 5970 tho... how well that will pan out will depend on the price difference.
5870 has slightly faster pixel and texture fillrate than the 360GTX - but nVidia cards have traditionally run somewhat more optimal in this regard so being so close they are likely to edge it by around 5-10% on realworld performance - then you have the extra memory bandwidth, better efficency in some parts of the shader pipeline, etc. which will be all together good for another 5-10% performance. Aslong as nVidia keep on the ball it should just about edge it over the 5870. The 380GTX based on teh specs is roughly 40% faster than that - maybe 45% pushing it - which would tuck it in behind the 5970 - tho it probably won't be able to touch it in games where multi GPU is good for 80+% gains.
But how exactly do you know this won't perform simalarly to a HD5970? even if it's a little slower, it has the advantage of being a single GPU based card.
Have you seen the size of the HD5970? it's a joke.
I think Nvidia's unreleased, unbenchmarked theoretical card might possibly beat something that is available today from AMD.
Or you could just buy an AMD card today and enjoy something which kicks everything Nvidia ACTUALLY produces right in the nuts.
Just a suggestion.
There are uATX cases that can take the 5970, IMO any full size "ATX" case that cant take ATX cards is a joke.
Thought he was standing the case on its front but no, can see the psu at the bottom. That's wierd
