- 25 Sep 2008
- Orsett, Essex
inam challenge accepted
inam challenge accepted![]()
Sorry Marine
Where are Nikaz and lewis, we are missing you guys.
Getting better.. I know where im losing time though, on the last two turns, cant seem to turn the wheel quick enough with one hand
confused...
...what happened and you had to re-install?
true they are a lot of bugs...
the force feedback settings seem to change between restarts.. and the sound bug is still there
anyways.. to the track..:
do you downshift down to 4th in the long right hander.. before the tunnel? or you keep 5th?
straight over jump 5th? and up the right after?
4th for the small bump? before the slow part starts?
oh!! i found that tapping the handbrake on the last corner brings the rear of car just right for fast exit.
so.. with all the above.. here is this morning session
getting better I think![]()
Hey guys, thought Id jump on the bandwagon and give this a go. Downloaded a savegame as Im not very far in at all but have lost my g25 settings now and finding it harder. I cant seem to get sub 1.34 with these. EDIT - Stupid auto breaking was on XD
Can anyone post the settings they are using?
thanks
