The New Cases Gallery
Nice, ive got a 4870 also which is great for gaming on a 24" screen.
Thats also very good to hear, was going to look for another 4870 for some cheap crossfireX but if money isnt tight (now i got a job :P) might go for a 5870.
Either way my GPU is the next upgrade in my sights :) .
I would wait to see what nvidia has lined up im sure your 4870 will last a few more months ;)
Even if you still want to go for a 5870 the price should drop a lot after the release of the GTX3xx series :cool:
Bought H50-1 at weekend and fitted it into HAF932 i bought off MM last week. I'm well pleased with the end result. :D
Before
Titan Fenrir in Antec 900
The end result
Yep i am for sure, found another 4870 online for around £100 tho so might give crossfire a try while we all wait.
After xmas tho :(
Much neater wiring in the new case, you must be pleased with the result
I am, very much so, thanks :D
Quick question - Why don't the 4870's look the same?
Bought a Powercolour 4870 (bottom) with reference cooler last year (£190!) and the top 4870 is an XFX4870 bought a few weeks ago from OcUK (£98, what a difference a year makes!). Better looking and slightly better cooling in my opinion.
CPU: Intel Core 2 Quad Q6600 LGA775 2.4 GHz @3.0GHz Akasa AK-961 CPU Cooler
Memory: OCZ SLI-Ready Edition 4GB OCZ XTC Memory Cooler Rev 2
Dual NVIDIA GPUs: 2 NVIDIA GeForce GTX 260
Sound: ASUS Xonar D1 Audio Device
Hard Drive(s): 298.0 GB, 139.7 GB, 465.8 GB.
Case: Akasa Eclipse-62
Nice set up Marlos. I'd be tempted to stick another cooler on that Q6600 and clock the twangers off it. Should perform really well with those to GPUs in SLi
I changed most of my fans around. Still a bit of a mish mash of fans and colours but slowly improving it. :p Replaced stock case fans from side cover and front panel with better cfm fans, removed the blue green fan from vga cooler, and added an ac ryan blue-orange to the cpu. Is it in any way improved from my last pics in terms of colours? Does the xigmatek work colourwise with the others? I've mostly got ac ryan fans now and considering replacing the enermax and xigmatek with ac ryans to at least keep a theme of one fan brand :)
All down to personal taste i think, if you like it then that's what's important.
My own personal taste is for more of a theme, keeping colours to 2 at most, makes things look more professional maybe
I like the look of the Black and orange case fan at the rear and also the ACryan blue and orange of the CPU cooler.
Still looking nice though, you've obviously put a lot of work into it.
Just noticed your RAM appears to be kn adjacent slots, you sure that's right?
