Have you read THIS thread mate ?
The profile tweak and / or card BIOS flash have cured this for a few
GL![]()
I've read guys that many have fixed their problems with Asus motherboards by manually setting the PCIE speed in the BIOS to 101mhz. It's worth a try at least, it may well fix most of the problems.
looking around the forums is generaly the mid/lower end 5xxx series that are having problems.
Ive mentioned this in another thread as well.
All the dies are the same just flashed differently. A 5770 die is a failed 5870/5850 die.
This is the same with all makers. The failed units on their high end are their mid to low end and with yeilds as bad as they were im not suprised that half the gpus are gubbed altogeather.
Sorry deano I don't know as I haven't had a megatrends bios for years. Usually it's on the same page in your bios as the cpu overclocking parameters such as FSB/multiplier etc.
This happens every time I click 'Auto-tune' in the Overdrive section of CCC.![]()
