***Official Left 4 Dead 2 Thread***
Someone give me a nudge if up for trying expert campaigns to get those achievements :)
I need some of those expert cheevos. I'm not bad at them. Last time I did expert was on an Asian server with over 500ping, and funnily enough I was the one NOT dying.
It is not reflective of my versus performance thou-
:p
Yeah used the sig one, will do it again.
edit: now says there is a problem adding you :p
i swear i saw duke then it vanished >.<
Gimme your name and i'll add you :p
accepted someone called substancer :S
and Damien.
and Damien.
Its because theres someone out there called Ricorodreguez so you're getting all there invites. What goes around comes around :p
It won't ever happen. no one will play the game if they're forced to stick around in a game full of morons, terrible publics or griefers so you'd end up with no one.
I got gifted this for Christmas but only found out later that it's broken with multi-GPU setups - the game lags and stutters at 20-30fps, unless you change setting or alt-tab out. It's quite ridiculous that the game was released in this state. I mean, I can get 200-300fps maxed out but I'm forced to jump through hoops on every level load. Valve really dropped the ball with this game.
No they didn't, runs smooth as butter here on an old E6320.
I'd imagine your problem is that you have multi-core rendering enabled which seems to cause problems and not provide any benefit. Turn it off and you should be okay. :)
psst antar,
its multi-gpu!!! (my 4870x2 has the stutter problem)
disabling multi-core settings ingame did jack, i just disabled xfire, i still get 70-130 fps so no problem for me
Im using a Microsoft notebook optical mouse 3000
For some reason any Source engine game makes the scroll wheel VERY sensitive so its almost impossible to go from gun, to pistol. I usually end up with a health pack. Now ive turned the scoll wheel option in windows way down but L4D-2 seems to ignore this.
Anyone else found this?
I'm missing this game so much now! Sky have told me it could take upto 90 days before I get DSL back....... 90 ******* days! Have even checked for unsecure wireless networks but there are none about :(
