- 22 Oct 2009
- High Wycombe
Muahaha fine based on your wealth.
More fines should be based like that, that way you can't just treat fines as some inconvenient fee to do what you want.
This.
Someone's income has no effect on the impact of their crime. The impact of a punishment on someone's income on the other hand, affects the proportionate impact of the punishment, including the deterrent effect.I ask again, what impact does someone's income have on the effect of their crime?
I think you also miss the reason why the cost of the crime is doubled to provide deterrent, it is to make the legal alternative much more attractive than the crime, not the arbitrarily punish the individual concerned.
If people repeatedly commit crimes, deal with that through repetition increases, fines would quickly become unaffordable even if you only doubled the previous fine each time, unless of course the impact of the harm was negligible in the first place, but then it's debatable whether the law should be in place at all.
That's not a bad alternative, though still leaves the issue that initially it allows the rich to flaunt certain laws until the increases become a big enough deterrent, ie. similar to the level it would be in the first place with means tested fining.I never said they should, that is why I would happily advocate the multiplication of fines for repeat offences, doubling the previous fine should do on each occasion.
Well yes but i've been discussing fines in general, i've already commented on how they are largely useless in terms of speeding anyway.Ideally deterrents should be restricted to behaviour that actually needs deterring, but that doesn't happen under our current setup...
Since when was fines based on coast. They are a deterrent. Does speeding at 100mph really cost £400 compared to £60 for 80mph.
if it was based on cost, it would be a fee a charge payable for damage. it is not, it is a fine a deterrent/punishment.
This discussion is way too polarised.
There are 2 massively opposing schools of thought, and neither will come close to convincing the other side. May as well let it rest tbh.
but with laws that are designed to hurt the lesser wealthy members of society?
but what is 'just' given that it is completely emotive and that one person could find one thing just and another something else entirely, i think you'd have to define your take on 'just' in this scenario
I'm not saying they are, I'm saying they should be in a just society with just laws.
To achieve a proportionate punishment to the harm, you need to consider the impact of the punishment on the individual.
If a punishment derived from the harm doesn't punish the individual, it isn't a punishment.
Why do they need to be, to have a just society? that does not make any sense. You are saying you should be able to spend your way above the law, that is not just or fair, in any sense.
Ignore speeding and take any other crime you feel has any real social damage. Do you think that should be a fixed fine, which people can pay their way out of. Or where prison isn't a suitable punishment a just punishment takes into consideration, income/wealth and is a percentage and thus effects everyone equally.
See above, and consider whether you think people should be treated differently for the same crime. ?
The cost and impact of the crime does not change (in most cases) depending on the criminal, so why should the resultant treatment?
Hence the scaling aspect for repeat offenders. That way you are still basing your punishment on the crime, not the criminal.
If you are accepting the principle of escalating fines providing an increased deterrent, then it must surely follow that someone's 'ability to pay' will affect the deterrent effect of any crime, as paying a lesser amount (proportionately) will be a lesser deterrent.Hence the scaling aspect for repeat offenders. That way you are still basing your punishment on the crime, not the criminal.
In a just society with just punishment, yes this should happen.Do we have to assess all punishments for the impact on the individual? s
where have I said treat people differently?
I am treating everyone the same, teh same percentage.
why are you treating people differently, that £60 is a lot bigger % than to a millionaire, who else are you treating differently?
Fines are not based on cost, they are based on punishment and deterrent, therefore a % is fair and just as it achieves the same outcome to all people.
Then you aren't basing the fine on the cost of the crime. You allow the poor to cause a disproportionate impact on society with their crimes because their fines are not related to the damage they cause. I advocate responsibility for actions, which means bearing the cost of your actions correctly.
The impact of a crime does not vary by %, so why should the punishment, unless you're back to basing the punishment on the criminal, not the crime.
That still effectively allows the rich to offend more than others up until the fine reaches a level where by it provides a deterrent.
Why not just use means testing to ensure that level is ascertained right off the bat and then you will deter everyone equally, all the time?
With repeat increases you will effectively just change the problem of 'the rich can buy themselves above laws' to 'the rich can buy themselves above laws for only a few times'.
Rather, why not base your punishment on the crime, with a form of multiplier/increase based on ability to pay to ensure the deterrent effect applies equally to all individuals?
Or basically, what they do now![]()
