my 4 motion r32 golf hybrid with added boost ;)
5 Jan 2010
the car started life as a 2.8l vr6 4motion with every option apart from sat nav. at some point somebody hit a rock and smashed the sump off the motor it got written off as cat d.
the previous owner to me bought it and a scrap r32 golf then proceeded to swap everything mechanical apart from the brakes
ie engine wishbones steering rack suspension arbs etc i bought it from him like that about 12 months ago
iv got some updates iv ordered a set of ecs stage 5 brakes these have 355mm 2 piece disks and porsche cayene 6 pot callipers and are ****** huge!
http://i39.tinypic.com/2qscdvc.jpg
heres what theyl look like under 18" wheels
http://url.photobucket.com/albums/v178/eatthis/DSC06189.jpg
http://url.photobucket.com/albums/v178/eatthis/DSC06200.jpg
iv also got my rotrex kit itl run 15 psi and make 475 hp and 400 lb ft :twisted: il get some pics up later of that
http://i43.tinypic.com/ka2yd2.jpg
very stealthy and itl go like ****
mods so far are
kw v3 suspension
nuespeed front and rear arbs
3 strut braces
poly bushes thoughout
75% reduced throw gearshift
race haldex controller (far more aggressive than stock and goes full 50/50 torque split also works off throttle position not just wheelspin)
boost gauge oil temp and oil pressure gauge
dubpower prototype big bore and port matched 6 branch exhaust manifold
full custom 3" exhaust system with big bore custom decat pipe
carbinio induction kit (makes it sound a little like the 12v vr6 which is a very good thing)
18" oz superleggeras with 245 40 18 potenza s02 (225/35/18s in the pic)
YouTube - exhaust
YouTube - launch
bits to do
get the brakes fitted
get the intercooled rotrex kit fitted with wossner low comp pistons
get the water injection fitted
run it in
go for 12s at santa pod :lol:
got the wheels refurbed and painted now theyr back on the car the problem with a good camera is it shows EVERYTHING lol
http://i40.tinypic.com/9j1xxd.jpg
http://i40.tinypic.com/2cmokug.jpg
http://i44.tinypic.com/281t0cx.jpg
i got my megs g220 out on the bonnet today iv done 1/3rd of the bonnet and it looks 50 million times better it looked like this this mornin
http://i25.tinypic.com/1z1y3o0.jpg
it now looks like this
http://i28.tinypic.com/2e533ok.jpg
http://i30.tinypic.com/289czde.jpg
http://i30.tinypic.com/25a543k.jpg
iv done the rest of the bonnet heres a better before and after shot of the bonnet this is the same part with the camera focused on the paint not the reflection
http://i29.tinypic.com/24et5rd.jpg
http://i31.tinypic.com/ixdx8o.jpg
http://i28.tinypic.com/2w74px0.jpg
cars gone in to get the brakes and the rotrex fitted iv found a cpl of vids of the test mule r32 its almost the same as my kit but mine will have 475 hp this has 450
YouTube - 450 bhp Rotrex R32 scares the mrs!
YouTube - Superchrged Golf R32 450bhp
YouTube - Rotrex R32 on take off!
been down to have a look at it today its in a million pieces. the heads off its been examined for wear (mainly chains/tensioners etc) and its mint
these pics are a good view of the vr6 lump 6 pistons in a v on a single head the 2.8l 12v has exactly the same layout
http://i25.tinypic.com/id7p5d.jpg
http://i29.tinypic.com/21ai7bs.jpg
http://i31.tinypic.com/k9tnnk.jpg
http://i25.tinypic.com/2gxhawo.jpg
Change to links, pics are WAY to big. If you want to resize them and re-host them please do so. Thanks. FF.
engines all run in and most of the problems are sorted just 1 persistent bugger that keeps throwin an engine light at me (theres too many sensors on this damn thing!!!)
had it on the rollers after 1k miles so still tight and was in limp mode it made 375 lb ft and 435 hp :) with FLAMES haha
http://www.youtube.com/watch?v=37GcqDYM1bU
http://www.youtube.com/watch?v=EMN3D5OaDTE
found a snowy car park ;)
http://www.youtube.com/watch?v=pm6urEneu-g
http://www.youtube.com/watch?v=x7egUIS70YM
exhaust noise
http://www.youtube.com/watch?v=HQZchyYuOSQ
ps how do i embed vids here?
You have to lose the grey mudflaps and lower plastic trim or do something about them being grey!
oh it comes up nice when i clean it properly
rear looks lower than it is because the front nearside wheel is on a kurb but no other wheels are iv had to get genuine r32 wheels on because i couldnt get the superleggeras to fit over the brakes :(
Properly would = it looking awesome all the time!
Get a tube of Chemical Guys New Look Trim Gel and use that for a few weeks, I promise you it will bring out the blackness and shine in those trim panels.
il bear that in mind
but trust me round here especially in this weather its filthy within 2 days of cleaning it the shape of the booft creates low pressure which sucks a lot of crap into it (also adds drag but thats another topic lol)
