nice completely ignorant and totally wrong comment
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
the suspension is kw v3 which is adjustable for height, bound and rebound
the ride hide is 10mm lower than stock so hardly stupid.
the front is fairly soft and the rear is harder (to reduce understeer/increase oversteer)
i have arbs front and rear again front is softer than rear for the same reason as above
i dont expect you to believe this but il say it anyway the handling is a lot sharper than a stock r32. turn in is much better mid corner traction is better and corner exit is much better thanks to the suspension and the torque biasing diff in the front (i want the rear diff as well but cant afford yet)
nearly solid engine mounts and poly bushes all round make the car VERY direct to drive ie it responds to your inputs quickly and accurately.
iv had the esp completely disabled from the ecu so the car does exactly what i tell it to do
