I've ordered the case with three 140mm fans. Move the rear one to the front, put two new in the top and one in the bottom. I'm then putting an Akasa Apache at the rear to be PWM-linked to the heatsink fans.
How is the airflow setup, are the top fans intake?
but what would you have a fractal for £80 and 2 new fans £20 = £100 or a antec p183 for £110 ? which would you say is better as its now only £10 in it when you add the fans to the fractal mmmm what to do.
would this case be much more silent than the antec with another 2 fans in the case over the antec which has 2 fans and be cooler
The Apaches are Silent but needs to be set around 950ish RPM this can be done with software via PWM. With all the fans running at low RPM you wont even hear it.would the case then not sound like a jet engine ?
