Sorry I meant something far more comparable to OSX than to the iPhone OS - IMHO its a joke that such a device uses an OS built for a tiny screen, using the excuse its tailored for touchscreens just doesnt cut it. The home screen pics just look embarrassing...
ps3ud0![]()
Just because the iPhone OS is used on a small screen at the moment doesn't mean it doesn't scale up well. The video of using it seems to show it working well with all the touch widgets of the iPhone. Yes the home screen does look a bit odd when you're used to the iPhones but when you think about it would you want a mahoosive clock or an unlock slider where you have to slide your finger all the way across the screen?
It could do with a few widgets though, I will probably be jailbreaking mine and sticking whatever fancy homescreen the hackers have to offer on.
