Probably because you were ruuning a tiny clock on the Q6600
3ghz is a lame speed for a Q6600
You should have saved your money and overclocked the Q6600 more
You haven't upgraded BTW
You have side graded
Intel® Core™2 Quad Q6600 - 2007-2009
Phenom® II™ X4 965 - 2009-2010
So because it's newer you should buy it? quite a simple response coming from you for a change.
Oh I forgot, no rules apply when buying AMD.
Not necessary, like not as a given but if I had owned a Intel®LGA775 chip since 2007 I think to be honest I would sell body parts to move up!So because it's newer you should buy it?
quite a simple response coming from you for a change.![]()
) so it's relatively new (in milage terms only just run in) Yes theres nothing wrong with buying just to tweak and experiment and generally treat yourself but I thought you'd condone "Bang for buck"? and while the 965 is around £30 cheaper than a q9550 for an overall performance advantage too, it's also going to cost someone with a 775 setup an extra £50-£110 to get a mobo to drop it into, not to mention memory depending on what board he has already.Of course IMHO think the Phenom® II™ X4 965 is a gratuitous expense but jonny-freshman can have a really nice time with it and try to get some 4GHz action without doing a degree in overclocking!![]()
Haha thanks . . . sorry I do like to give someones grey-matter a workout sometimes, I mean no harm, it's just who I am, I help people as much as possible!![]()
Yeah I do for myself personally and anyone with limited budgets etc but I'm not shoving that down your throat heh!I thought you'd condone "Bang for buck"
Most wouldn't do this but I would jump at the chance . . . for £0.00 if possible!Bang for buck tweaker said:Intel® Core™2 Quad Q6600 - 2007-2009
Athlon® II™ X4 620 - 2009-2010
Put my order through thanks to my Girlfriend (early birthday presant).
Should be seeing the kit on Monday, build piccies will be provided for AMD fans.
What about Intel fans and non Intel OR AMD fans, can they look?![]()
Nice upgrade mate![]()
For 9/10 games the Q6600 clock for clock should be pretty close as makes no difference maybe even faster in some cases to a 965. I think there must have been something wrong with the intel setup.
