You really want to be working in one area at once, there is some info about getting RAM above 1600MHz on a UD3R at Tweaktown Forums but for now you just need it at atleast stock but preferably lower.
 are these settings ok, will running a lower multiplier do any harm?CPU Clok ratio 21x
QPI Link speed x36
Baseclock 191
Performance Enhance - standard
XMP disabled
System memory multiplyer SPD - 8.0
intel turbo boost - disabled
Cpu cores enabled - all
CPU multithreading - enabled
C1e , C3/c6/c7, thermal, EIST and PROCHOT all disabled
Virtualization - enabled.
Uncore freqency x17
Isochronous supprot - enabled
PCI frequency - 100
CIAZ -disabled
CPU clockdrive 800Mv
PIC Express clock drive 900Mc
CPU cliock skew 100ps
IOH clock skew 0ps
Local-line calibration - disabled
CPU Vcore 1.300V
QPI/VTT coltage 1.295v
IOH Core 1.16V
DRAM Voltage 1.640v
everthing else is as at default / auto
max temp 78. is there any way i can make my cpu fan run faster sooner or perminantly on my mobo to keep the temps down as noise isnt an issue?
will try and lower my vcore to see if i can get temps down.
i am![]()
i am![]()
max temp is 78c is fine and why put: CPU clockdrive 800Mv ?
CPU cliock skew 100ps ?
change it to 700Mv and 0ps
rule of thumb for X58 4GHz clocks
gigas like 191X21
asus likes 200X20
I'd enable Load Line Calibration, it solved a load of stability issues for me.
Didn't solve any stability issues which more vcore wouldn't have, and may have introduced problems.
I was setting mine at 21 x 181 for 3.86GHZ, vcore 1.27500 and qpi on auto with ram volt or 1.66 I did prime 95 for 4 hrs no errors no reports and max temp on full load was 69 degrees..
Last night I got a little freaked out as I have this horrible feeling that my system may blow up with the voltages lol .. I never overclocked before this was my first attempt.. but thought to myself "is thee really any need for overclocking for what I use the pc for (photoshop, lightroom, movies etc..) I am not a gamer by any means..
However the thought of having it run at 4.0GHZ just makes you want to have it.. so would you guys reccomend I set up again tonigt? This time at 21 x 191 , turbo enabled , vcore 1.30000 (or shall it be lower) timings for my ram is 9 9 9 24 so I will set them too what should my uncore and qpi multiplier be also what should my ram volt and my qpi and ioh voltage be . pleaase guide
Thanks ..
PS: when I was hitting 3.8 GHZ there were 4 little blue lights constantly light up when pc running on the top right of the mother board which I think indicate the level of overclocking .. is this safe? how many blue light should it be max? and there was a small green light which was on by the ram when I put the ram voltage to 1.66?
what mobo do you have? is your i7 the D0 or C0? what cooler are you using?
