i3 530 OEM
Coolermaster TX3
GA-H55M-UD2H
4GB Patriot 5 G series PC12800
This works well for me.
The onboard graphics won't run many games, except maybe WoW and stuff like that, but will be fine for watching HD videos which is generally what it's designed for.
dont waste your time i3 arent worth it let big wayne spec you an amd rig instead im sure he can find something cheap with onboard gfx on the mobo which would be faster than the intel oncore crud.
if you cant afford an i5 750 then theres not much point buying intel imo.
dont waste your time i3 arent worth it <Snip>.
Users need? . . . Bundle Price?![]()
i3 530 OEM
Coolermaster TX3
GA-H55M-UD2H
This comes out at £275 with free del. Runs at 4GHz 24/7 easily.
Also faster than Athlon II x4 in games
Also doesn't it use significantly less power?
So apart from
Being only £275
Being faster in games than Athlon II X4 Quad Cpu's
Using significantly less power
Being able to stream HD master Audio without the need for Sound cards
Being able to clock to 4ghz with ease
Having all the lastest instruction sets
And being 32nm
