Perhaps someone more mechanically minded than myself could take a look at my problem and advise. I have sent a message to Joe from Redsnapper but I doubt he will pick it up untill Monday. (I'm off to Cornwall Sunday?!)
The problem: Whilst using the tripod the leg more or less feel off becuase I turned the leg an extra turn too much!!
The bits: Here's what I have to re assemble!!
1 - thin ring
2 - fat ring
3 - big ring
4 - 2x plastic pads
5 - leg
6 - duo-pod
7 - twist lock tube
What I think I can figure: The fattest two rings wont fit in the actual tripod leg bit as far as I can see. The two white pads clearly sit upon the leg. The thick long ring probably goes somewhere into the locking mechanism. Apart from that I'm stuck. ?? Help??
Please
1 - thin ring
2 - fat ring
3 - big ring
4 - 2x plastic pads
5 - leg
6 - duo-pod
7 - twist lock tube
Please
