- 2 Oct 2007
- Oxfordshire
Why have they been taken off then?
hopefully the new FW sorts it, not much more to add until then
[ZiiP]carrot;16002720 said:Little update from my with my new HDD. As I don't want to put my new SSD into my PC until it's got the new firmware out, I decided to test it out on my laptop. It's an Acer 2930z (Intel C2D 2GHz, 4gb ram) and the below results are the laptops standard 250gb 5400rpm HDD.
NOTE: In case it affects results, the standard laptop HDD had all my normal stuff on it (programs, music, photos etc) and I've just discoverd it was 13% defragmented, while the SSD results further down was with just a clean install of W7, Firefox and AVG installed
Laptop HDD
SSD
My write results seem a lot higher than yours razer![]()
yes a little higher but i used the 1000mb test haven't tried the others, to be honest i'm waiting for the next firmware to come out as others on there forum are having problems with the one that's out at the mo (2.008 i think) as it's wipes the drive during the update so until then it's just going to be sitting there......... hopefully not much longer till i can use this drive![]()
Is there any confirmation anywhere that upcoming firmware is going to fix the 4K read/write speeds?
Atm they really are quite shocking but if they can sort them out to something better than a normal HDD these might be worth a punt for the price. Obviously they will never compete with the higher end drives but being better than a mechanical HDD would be nice!
