Need for Speed Shift - Time Trial Championship ** Season 3 ** (Multiplatform)
Well ive managed to grab some time to play it this morning, heres the best i can do.
http://i46.tinypic.com/2wqcoex.jpg
Unbelivable laptime nikaz:eek: Well played mate
Much appreciated nikaz, i will give them a whirl in abit :)
No probs
Around the 'Carousel' the long right curve, try & follow the racing line. On entry you should be nearly maxing 3rd gear. Follow the line & when it turns red change up to 4th. Now start feathering the throttle to keep on the line. When you see the apex on the right leading to the mini straight FULL throttle letting the car ease out to the left on exit. You can take/use the curb here. Drive onwards snatching 5th just before the curbing on the left for the fast 'Kink' right. This is taken in 5th FULL throttle.
Any other corners you want help with just shout.
Hi everyone, I might make a return this week as work and home life has calmed down a bit.
Can't wait to see the next challenge tonight! :cool:
Good time inam.
Where are you losing time compared to my vid?
I know it's late in the week but I could post my settings. May help break the 59 barrier.
Mainly on last two sectors, but where exactly i am loosing the time is hard to tell. Thanks for posting your settings again but not going to get any more time today.
FINAL STANDINGS Season 3 Week 2 Leaderboard
Pos Lap--time Split-Tm Pts Driver
01. 01:57.600 +00.000 25 NIKAZ
02. 01:59.270 +01.670 20 inam22
03. 01:59.380 +01.780 16 danswan
04. 02:00.120 +02.520 13 Wedge
05. 02:00.320 +02.720 11 mercyless
06. 02:00.550 +02.950 10 Lt Goody
07. 02:01.030 +03.430 09 Marine Iguana
08. 02:02.100 +04.500 08 666_Pounder
09. 02:02.320 +04.720 07 lewdogga
10. 02:02.410 +04.810 06 Merlin5
11. 02:03.750 +06.150 05 CK61938
12. 02:05.150 +07.550 04 grs_link
13. 02:06.100 +08.500 03 anihcniedam
Well done inam & danswan for hitting the low 59's.
Good show everybody for being within 10's of my time, especially those within 5's. It was a tough combo for learning throttle control.
This week's challenge should be very close. The Renault is a very easy car to drive & has a surprising level of grip with very little understeer for a FWD. I expect somewhere around 1.5 to 2's separating the top 10.
Probably a stupid question, are we just using the stock car? Or upgrading it and just not using works?
You can upgrade as much or as little as you want.
mercyless didn't specify 'Works Converted' so you can upgrade the car to level 3 upgrades & use NOS or you can fully upgrade i.e. 'Works Convert' but you lose NOS capability.
Personally I'm using 'Works Converted'.
Thanks Nikaz, but your time of mid 57's was just unbelieveable i don't know how you do it and congrats on winning 2nd week as well.
