- 19 Oct 2002
- Torbay, Devon, UK
I have tried 10.1 hot fix, 10.2s and the 10.3 preview.
It must be like processors, some overclock better than others.
but isnt flashng the bois as dangerous as enriching uranium ?
the possibilities of bricking the card are there, then your stuck with with a wothless card
Flashing GPU's BIOS voids warranty anyway, doesn't matter if you brick it or not you won't have warranty.
Not really true, technically your warranty is only invalid if you brick your card with a bad flash, however it's very easy to fix a card with a bad flash.
They only say that to cover people trying to flash a card when they don't have a clue what they're doing.
In addition, new bioses are released by manufacturers every so often to fix bugs and that so it's not really as simple as you've made out.
Basically there's no way of them finding out that you've flashed your bios especially if you flash it back to stock if it ever needs to be sent for RMA.
