I don't really see the purpose in comparing the temps... using a higher voltage on the 930, of course the temps are going to be higher... The same way you could take 2 920s that require different voltages to reach 4GHz, which doesn't give anyone the "right", to say oh dear look at that one, it gets hotter than that one... of course it does more electricity is being pushed through it lol. In the same respect 2 930s will require different amounts of electricity to attain the same speed.
All that chart draws a conclusion to is more volts = higher temps, but we all knew that anyway.
Even 2 chips, made exactly the same day, at the same time, at the same place on the same wafer might require different amounts of voltages to achieve a high clock. No chip will be the same it is simply the law of physics
