It should be faster, mine are these:
I did install the Marvell SATA 3 drivers for my controller
Your board also has a Marvell controller, have you done the same?
My controller is also set to AHCI.
The driver is here:
http://www.gigabyte.com.tw/Support/...?ProductID=3234&ost=windows+7+64bit#anchor_os
EDIT: Is it plugged into a SATA 3 socket?
I've already installed this, but the drive isn't being controlled by it. Yes it is plugged in to a SATA 3 socket![]()
Rocketman I believe the pciide from as ssd bench means you are running in ide mode not ahci.
It does look as though the C300 is being recognised by the OS as a SATA2 device. Did you do a new install of windows on this SSD?
http://img532.imageshack.us/img532/2158/marvell.jpg
The driver is here:
There's a newer driver available btw, also updates the config device driver.
http://www.station-drivers.com/tele...ru4.1.0.1601-all(www.station-drivers.com).exe
I've seen that before and it's an OEM driver set-up package.
You can just update the controller/config device manually though, done it on my Gigabyte mobo.
The driver adds a new policies tab so you can disable safely remove hardware icon and enable/disable the caching.
No, its a drive-to-drive clone of my crucial m225 256gb. I had hoped using Acronis TI would save the hassle of reinstalling![]()
Is it so much of a hassle to do a reinstall? Personally I would do a clean install with the C300 to see if it makes a difference. Just run the benchmark again before you start a couple of times to confirm that it is still the same as before.
The only two places where the C300 and controller show up are here are ‘disk drives’ and ‘storage controllers’:
I'm on a ASUS P6X58D, have you tried your motherboard support forum?
