The Project takes it's inspiration from the Cobra helecopter Gunships first used in the Vietnam war and pretty much all wars since in one form or another
The Bell UH1 Huey Gunships of the US Army, 174 Sharks Assault Helicopter Company were one of the many to utilise the "Sharks Mouth" motif on the nose of their Aircraft. I am aiming to incorerate this motif into the build.
As you guys know the Cobra Gunships also feature in CODMWF2 so I may build in a referrence to the game also. (open to suggestions)
The chasis for the build wuill be the Antec Skeleton case. Bit of a marmite case I know, I've built and modded one before and love working with it. I also love the high overclocks you can acheive with it on air alone thanks to it's unique cooling solution.
Those who remember my last build will know that in order to fit a large heatsink it's necessary to cut the cowling at the back. I'm not planning on doing that this time, instead i'm going to use the Zalman CNSP9500LED. I used this cooler on my Q6600 a while back and was realy pleased with the temps. It seems to work really well with the "top down" airflow of the Skelly.
First steps are to open it up and take it apart.
It takes about an hour to totally disassemble this case (about 20 screws)
It's made from High density plastic, with steel reinforcements of the struts to the fan area.
I'm also planning to incorperate the MESH KIT made by Antec. The mesh kit serves very well at keeping out the prying fingers of children, however i'm using it for no other reason than I like the look of it.
Assembled with mesh kit just to make sure I know where it all goes!!!
Next job will be sanding and prepping all the panels for painting. (now that it's warmed up a bit in the shed!!!
