Intel Rapid Storage manager (Intel Matrix Storage Manager) now supports Trim
18 Oct 2002
N.Devon
http://downloadcenter.intel.com/det...D=&DwnldID=15251&strOss=&OSFullName=&lang=eng
Copy and pasted from help section of RST:
Our application also provides support for the following features:
• Password-protected disks
This feature provides high-level security and protection for the data on your disks with a password, denying access from any unauthorized user.
• Trim (Microsoft Windows 7* only)
This feature provides support for solid state disks (SSDs) that meet the ATA-8 protocol requirements. This feature optimizes write operations, helps devices reduce wear, and maintains unused storage area on devices as large as possible.
Edit:
After reading up it seems these drivers won't allow TRIM on RAID'ed drives only on drives outside of an array.
^ Yeah it is! Intel have produced a good RTS driver set this time and I'm seeing improvements in benchmarks rather than a reduction with previous releases. Throw proper TRIM support into the mix and we have a winner. Some bench numbers for 80 and 160 GB drives comparing MSM vs RST.
80GB G2
MSM v8.9.1023
AS SSD Benchmark 1.4.3704.27281
Name: INTEL SSDSA2M080G2GC
Firmware: 2CV1
Controller: iaStor
Offset: 1024 K - OK
Date: 20/03/2010 20:58:27
Sequential:
Read: 257.06 MB/s
Write: 85.46 MB/s
4K:
Read: 21.87 MB/s
Write: 48.66 MB/s
4K-64Threads:
Read: 148.66 MB/s
Write: 57.79 MB/s
Access Times:
Read: 0.094 ms
Write: 0.087 ms
Score:
Read: 196
Write: 115
Total: 412
RST v9.6.0.1014
Firmware: 2CV1
Controller: iaStor
Offset: 1024 K - OK
Date: 21/03/2010 01:40:26
Sequential:
Read: 257.35 MB/s
Write: 85.25 MB/s
4K:
Read: 22.62 MB/s
Write: 54.24 MB/s
4K-64Threads:
Read: 149.32 MB/s
Write: 58.53 MB/s
Access Times:
Read: 0.082 ms
Write: 0.077 ms
Score:
Read: 198
Write: 121
Total: 421
160GB G2
MSM v8.9.1023
Name: INTEL SSDSA2M160G2GC
Firmware: 2CV1
Controller: iaStor
Offset: 1024 K - OK
Date: 20/03/2010 21:01:28
Sequential:
Read: 257.35 MB/s
Write: 106.91 MB/s
4K:
Read: 20.78 MB/s
Write: 50.20 MB/s
4K-64Threads:
Read: 154.98 MB/s
Write: 65.67 MB/s
Access Times:
Read: 0.144 ms
Write: 0.089 ms
Score:
Read: 201
Write: 127
Total: 432
RST v9.6.0.1014
Firmware: 2CV1
Controller: iaStor
Offset: 1024 K - OK
Date: 21/03/2010 01:46:54
Sequential:
Read: 258.04 MB/s
Write: 99.65 MB/s
4K:
Read: 22.06 MB/s
Write: 55.23 MB/s
4K-64Threads:
Read: 154.68 MB/s
Write: 65.61 MB/s
Access Times:
Read: 0.132 ms
Write: 0.078 ms
Score:
Read: 203
Write: 131
Total: 438
Intel X25-M G2 80GB in AHCI mode with Win 7 (64bit):
v8.9.0.1023
v9.6.0.1014
Seemingly this new driver still does not let TRIM run in RAID0 (I am presuming neither automatically not by Intel SSD Toolbox), this is very disappointing I think...just to make sure I might just set up my 2 SSDs in RAID0 and see exactly what the situation is...
v8.9.0.1023
v9.6.0.1014
Yeah i read that Intel are still researching whether it is possible to have TRIM work on drives in an array.
At the moment i`m using the standard AHCI drivers that are built into Windows 7 on laptops Intel X25-M Mainstream 80GB so I can have automatic Trim, so i take it I can now replace these drivers and upgrade to this new Intel Rapid Storage manager drivers and not need to worry about having to use the Intel Solid State Drive Toolbox software???
Thank you for responding.
Yes! :)
One more thing I was wondering about was can these drivers be used with with normal hard drives in AHCI mode as well??? and are these drivers just the same as the Intel Matrix Storage Manager drivers but with newer features and newer build version and so is really a replacement for the IMSM drivers???
Thanks for responding.
v8.9.0.1023
http://img.photobucket.com/albums/v245/jbloggs/2010-03-10_171114.jpg
v9.6.0.1014
http://img.photobucket.com/albums/v245/jbloggs/2010-03-20_105151.jpg
Did you manage to find out ?
As it seems strange they`d put this in their help file if it didn't work :confused:
TRIM support is provided for all volume types except RAID 5
see the note at the bottom of the help file Creating a Volume > Creation process > Configuring the Volume
On a plus side the hot swap now works correctly with these drivers, compared to the MSahci ones
TRIM doesn't appear to be supported on my RAID0 volume using these new drivers, the SSDs are greyed out in Intel SSD ToolBox...
Help section built into IRS windows console.
Introduction>Getting Started>about 2 thirds down the page
Or just search for 'trim' in help section
Intel SSD Toolbox is probably doing taht because it has'nt been updated to be 'told' it ok to mess around with RAID'ed drives.
They are replacements for IMSM.
Wish Intel would actually communicate with their customers even on the official forums everyone is left guessing.
Toolbox sees the RAID0 volume as 2 separate volumes (not as one large volume as it did with 8.9.0.1023), but both greyed out, however, when running as 2 separate SSDs in AHCI mode the same version of Toolbox sees them and TRIM can be run manually...I'll let someone else sort out the ins and outs of whether or not TRIM runs on a RAID0 volume with the v9.6.0.1014 drivers...
Seem fine here (2xSATA HD, 1xSATA DVD burner). Still running the previous version of this driver, will install these tomrrow.
