If you're allowing straps I would allow belts. In PLing belts are legal, straps are not![]()
True.
They're both substitues for weak links in the lift. A weaker core being worse imo.
Try and film it if you can lads be good to see you all in pain
we all did this wed night the rules are
200kg on the bar
all reps are to touch the floor but not stop on the floor
if you rest you must rest at the top
only belt allowed
and all reps must be locked out/no half reps
Can I suggest a change? Make it time based. 1min to rep az many times as possible.
oh and can we use chalk or not?
Yeah i would say 1 min, as many raps as poss, rest wherever (like the . If you need to make even a tiny adjustment (shifting your leg/hand), doing it standing with 2xBW in your hands is asking for trouble (not that i can even do 2xBW atm)
Benny I think we should scrap the 1s-2s pause and just have it done in a timed scenario as has been mentioned 1min. Means you can pause as long as you want.
Think i might give this a go in a few weeks time, but i wont have a video of it so you will have to take my word for it
I would try the 2xbw with straps, weight would be the same as Freefaller (200k).
If all goes well in the next 8weeks, hopefully I will be able to beat my 1rm also, so hopefully will be able to get a few reps out with 200.
Im aiming high, i must beat Freefaller![]()
Yes but you have longer arms![]()
League 1 (No Belts or straps)
Name ---- 1x BW --- 1.5x BW --- 2.0x BW
League 2 (Lifting aids allowed)
Name ---- 1x BW --- 1.5x BW --- 2.x BW
I think vids are definitely required personally.
