- 26 Apr 2004
- Milton Keynes
It's realtime, but with limited movement. Basically you have a certain amount of run time, which differs from unit type to unit type, each time you move, you use some of said movement time, you can stop and fire whenever you want, but enemies will attack you whilst moving if they can see you and are close enough.
Its not block based. There so many ATB schemes its easiest to just descibe it.
. But i'm back on the JRPG buzz and my copy of this arrived today.
