That may have gone over my head, but were you being ironic?![]()
kylew wishes to speak to you.
I know where yeovil is, its on the best side of the country.![]()
Yea, im not taking it personally, since it is freaking stupid tbh. Im pretty lucky that I can do it. Being single = lots of monies for myself, which tbh im loving it atm, had holiday at begining of march, gotone at end of april, bought 3 new cards, and buying a htpc. now, that is not my normal spending habbits, and i had saved for a good 6 months (I save at least £300 a month normally, more if i make any extra from overtime or trading). IF I were to go out and get myself a new GF, i doubt I would be able to afford any of this lol, and WIFE....Im only 24!
Now, someone go and post in my media center build thread to advise me on my FIRST EVER ATI card!
I'm guessing Ch3m1c4L should be able to beat these benchmarks.
If in doubt, take it out of context![]()
Actually your out of context as the GPU is specialised & only at specific tasks which the CPU is also capable of but the CPU is much slower at.
The GPU has massive limitation where it has to send stuff back to the CPU because the GPU simply does not have the functions.
So its nothing todo with not having a CPU licence because a GPU maker has no more right than creative sound card maker to a CPU licence because there soundcard market is shrinking as onboard sound is getting better & better.
No, you need an x86 license to be able to run Windows unless you give MS a nice payoff to port Windows to your new architecture, you don't actually NEED to have x86 to make a decent CPU and chipset - the problem comes with then only being able to run Linux/Unix.You need an X86 licence to make CPUs compatable with the established standard.
I have no idea what you are talking about. You need an X86 licence to make CPUs compatable with the established standard. And to get one, you need to get into bed with Intel. AMD have a deal with them.
Nvidia tried to aquire VIA because they have a licence, as a workaround.
It's pretty well documented? Nvidia have wanted in on the CPU market for years, why wouldnt they, they already make motherboard chipseets and GPU's, GPGPU is a natural reaction!
the GPU can't be confused with a CPU
the CPU is needed like it or not, Nvidia is only trying to make it possible to use the GPU s power to help out the CPU on CPU intensive apps NOT replace it
Also Nvidia probley won't get one to make x86 CPUs anyway...as it will be expensive they might as well do what they are doing now
You cant make a compatable CPU without a funny handshake from intel.
My point being, Nvidia want access to mass maket commercial CPU production - that means X86.
The issue is Microsoft only supporting x86 for Windows, which is the dominant OS around atm
