It's £37 on the EA download site.
Anyway: £29.99 on Steam and downloading at 2.3MB/sec. I'll log onto the OcUK server tonight (assuming the OP is still valid) and you can all have an easy kill.
Weird. I don't seem to have any eyefinity problems, though I did re-adjust my fov a few times before it felt 'comfortable' to play.
not played around with the FOV its just left at standard, ill just stick to single screen for this game as i usually have procon open on one and stats list on the other so i can see which guns i need to use for which stars![]()
Recreating Karkand with the type of houses that it is built up of in BF2 in a fully destructible environment and with the ability to enter each and every house on every floor and at the same time keep an acceptable performance would not be possible right now with the amount of destruction currently in the game.
Making these buildings indestructible and closing off all indoor areas would also not be consistent with the rest of the game as it is.
I actually had to scale down the size of the town in Arica Harbor a number of times during production in order to get an acceptable performance in addition of removing some buildings that was cut during development.
It's not just "a case of rendering it with the Frostbyte 2.0 "
Karkand has a very static environment. Only a few buildings lets you go inside them, no building takes any damage what so ever and only a couple of banger objects has any destruction.
So in BC2, a full blown Karkand is not going to happen.
I read that as "You must hide in the shadows and camp as much as possible to avoid Gustavs, trying to do the objects is an immediate fail". This is ironically the reason behind a lot of people going Recon to look after there KDR and kill people before they can retaliate and no-one complains about that![]()
Well then you are just an idiot who moans about a problem then ignores good advice to get around it. When I play recon, I only use it for the C4, gilly suit and motion sensor, and I almost always use the G3 or shotgun... Avoiding being seen a lot isn't a case of finding a lot of shrubbery and sitting in it... it's usually just being reasonable when you go somewhere, and not going out in the open if avoidable
No its called a stat whore. Keeping out of the open is logical, but its remarkable how many people will be content with just sitting somewhere at the side to kill people who don't know where they are instead of actually trying to push forwards. Because you know, you're supposed to arm/defuse charges but its ok, the rest of my team can do it, i'll just sit here and look after my score.
Ah so xp from any class unlocks everything eventually.you dont really go fro unlocks they just come with the amount of play you get. id say easiest to level with is the medic. but you have to wait until you get the defib and health pack to get easy points
Sadly true.
uv quite amusingly pointed out the other day that recon has my worst KD ration. Lol :/
It's annoying when you or a couple of your mates are the only ones attempting to push forward , if absolutely everyone apart from a couple of snipers pushed then you're bound to get the bombs armed at some point. I only really go sniper when I feel the need to cover a planted bomb site or defend a bomb site.
