I went and bought myself:
Auto Glym Aqua dry chamois
just ordered http://www.cleanyourcar.co.uk/washing-and-drying/foam-lance-various-fittings/prod_371.html
and the Valet Pro - PH Neutral Snow Foam
Should have some fun with that!
anyone use thesse?
It takes me 5 minutes to get the hose out
edit: so to speak![]()
First the car wash, now the chamois
Now for meaningful contribution....You need to get a proper drying towel, something like this from www.polishedbliss.co.uk
Be sure to check out their guide section too
A chamois is bad huh?![]()
as bad as a Aqua Blade.
I went for both of the above roughly a year ago. Lance is still working sound - definitely a good buy!
The trick to good foam (i find) is use only a small amount of the snow foam (say a cm or two in the bottom of the bottle) and add a few squirts of shampoo in. Top up with warm water.![]()
^^ I find fast glass great, maybe its the cloth or paper you're using which is causing problems? Its a pain with microfibre but with paper towels (the kind of blue industrial ones) it works great!
