- 1 Oct 2003
- Huddersfield
One thing i cant make out does the comp and the pro 2010 models have the same frame?
I believe they have the same frame.
I have the older model Enduro (2007-2009) and would love to try the new one. You should check out mtbr.com and the Specialized forum in there, there's obviously tonnes of threads on the 2010 Enduro and 'which is best!??!' threads.
From my reading of the stuff over there the new model apparently has a much stiffer rear-end and the new suspension design copes much better than the previous with small bumps, it's also a lot beefier around the chainstays (they have one at my LBS and I was quite surprised how much they'd beefed it up), it's definitely more towards the aggressive all-mountain end of the spectrum than the slightly more XC oriented previous model. A lot of people seem to like it, a few don't like the look of the new frame, I'd personally say screw that if it rides good
It has broke at the crank arm? Got some piccys?
