Anyone suggest a really good interior glass cleaner please I have tried Fast glass not impressed. I have all my external glass cleaners but they are a pain to use on inside windows like the front.
cheers
, #26 wax and some polishing cloths to remove product.
Had a quick go at removing some swirls on the other halfs car.
From this
To
Need a faster cutting pad and maybe some Menz 85RD 3.02 to remove the deeper scratches.
Small pad, primed on another panel would be my way of doing a wing mirror, failing that, a very light cut and LOTS of elbow grease.
Trouble with working a large area in one go, is that you will struggle greatly to get proper coverage, and work it all evenly and without it drying out.
So mask into quarters removing the tape once each bit is done and do the remainder?
is washing your car once a week a bit excessive?
no, 2 or 3 times a week for mine, black is high maintenance though.
is it necessary to wax my car each time i wash it? a friend of mine said there is no need to wax each time i wash it and that he only waxes his once every 3-4 months.. but doesnt a wash take off the existing wax??
he is right
i'm wondering if a quick rinse with water will just wash off the pollen...
most of it, some will be left though so you won't be able to dry the car without dragging it all over the surface and swirling it up. If that light pollen dust is a consistent problem then I'd get a California duster for it, and keep the car waxed nicely so it doesn't bond.
[IMgytyG]http://i745.photobucket.com/albums/xx91/mailboxffs/Pollen.jpg[/IMG]
looks like a cat has been on my car![]()
