WELL. 2 months later, a replacement arrives, and thankfully it works. The case is a loud *******, and the insides aren't even doing anything (idle at BIOS - trying to figure out how to install FreeNAS on a USB pen for some experimentation) but I intend to replace the fans with some that are either a lot quieter or completely silent (if possible). All in all a fantastic little case, very robust, but just a tad loud at present.
Do you think with some setting up, this tower/system could be run whilst in the same room as sleeping?
Planning on getting one myself, Looking at the Atom 330 with 1GB ram.
Edit - How is that hdd mounted on the box at the (botttom?) of the case in the first picture?
Sorry for all the questions, but I take it the slim ODD cover plate is included?
The ODD cover plate is indeed included, and it not only holds a slimline DVD drive and a 3.5" hard drive, but it helps with the stability of the whole case, turning it into a solid barrel of muscle.- I doubt it could be ran in the same room whilst sleeping without some tweaks, i.e. turning the case fan RPM down a fair bit or changing it altogether, I haven't went near this thing in ages because of moving house/can't be arsed/various other issues so I haven't done this yet, but it really is quite loud.
- The 2.5" HDD is mounted with screws that come up from below. I'd take pictures to show you, but there's a terabyte drive stuck in there nowThe ODD cover plate is indeed included, and it not only holds a slimline DVD drive and a 3.5" hard drive, but it helps with the stability of the whole case, turning it into a solid barrel of muscle.
Your not allowed to on Atom boards.
Few questions if I may....
1) The box at the bottom of the case below the 2.5" HD is for a 3.5" HD?
2) Can one be mounted where the 2.5" is as well (losing one of the PCI slots no doubt)?
3) What connectors does the PSU come with?
4) It does take a full height 5.25 drive OR a slimline and a 3.5" depending on choice yes? Does it include a fascia to allow the slimline drive?
Thanks
Meth
I have just recieved my BM648's and I'm a bit annoyed, the 5.25" bay has a blanking plate with a cut out for a slim line optical drive but no 5.25" complete blanking plate or a plate to blank off the slim line optical slot. Probably not a problem for most people but it is for me as these won't have optical drives grrrr.
Sorry to stir up old threads...
But, where'd you get your desk lamp OP?
QUOTE]
Well my Zotac Ion-F-E N330 (which is a dual core atom board) has one, it is the reason that I bought it. It will accept x16 pci-e video cards or x1 pci-e tv tuners quite happily
