Thanks v much mod1fied
Could I ask for a photo of the inside of your case if poss? I'm thinking to remove the drive bay, the PSU and fit a GA-G31M-ES2L microATX mobo. It's smaller than standard mATX so should fit once PSU is gone. The case is big enough but it depends how much space from the standoff to the bottom edge of the case exists - ie can I fit the WIDTH of the mATX board (9.6")
Hmm interesting idea.
Not sure on how you would mount it or power it
Basically the PSU is about 1" wide which is at the front of the case.
Ill try to get a pic up once I get home (OcUK @ work )
Just scrolled back through the post. The first picture shows the case internals. The right hand side of the case is the "Front". the small block you see with the fan at the top is the psu
