Can you plan cannon fodder with a mouse using this emulator?
Ooooh i hope so!!
afterall.... War has never been so much fun!...
I cant access that site at the moment, bloody watchguard! does anyone know if Cytron is on the list? loved that game!!
If it doesn't work right off the bat , just press F12 and configure the controls then ok/apply.
Nice to see your back neil.
Do pc joypads work ok (in general)? Or are they a pain to set up?
Whats this game?
http://i42.tinypic.com/fu2oao.png
Im being asked for a WHDLoad key. Do you need it ?
Ive got Eye of the Beholder 1 , 2 and 3 on the PC (all originals)![]()
Did you change the original destination folder?
I had troubles to start with, win7 seems to change the original location and muff it all up (if you change the installation dir).
It all needs to go into a file called WinUAE in c:
1. Use 7zip or winrar , unpack the GAME pre installed package exe. It should make two folders inside a main folder , Games and another one Configurations
2. Copy the game directory inside the Games folder for example 1164_project-x_whd into HWA\Games
3. Copy the Configuration file from Configurations into HWA\Configurations
4. Go into your HWA\Configurations folder and load the game configuration
5. Press F12 While in game to config graphical filters and or display![]()
Neil79, as you seem familiar with this stuff. Have you ever used KGWHDLoad files? Would be interesting to know if they would work with HWA.
Just click no
But do they have automap built in ?![]()
automap?
not complete maps, no, i printed them off years ago from my mate![]()
Well these AGA remakes have automap built in , press tab and wolla automap
Though i did the same as you years back , either printed or hand drawn![]()
