Trying handcent again, is there a way so that if I quick reply using the pop up that it clears the standard message notification?
Still no easy way to do a screen shot from non root phone?
Download the Android Developer program to your PC allows you to do it
Is there any way to get rid of the lack of space symbol from the status bar?
Doubt it. If hitting Clear doesnt do it then nope
I Cant find the setting to only show a certain contact group in the settings?
People > Menu > View > Tick the ones you want.
If you mean hiding them when you hit PHONE or add ppl in MESSAGES then no, there is no way to hide them yet.
Also wish I could just king press on a file and it would bluetooth over
I just press and hold the file then choose SHARE and choose bluetooth... Is this not possible for you ?? Tell us exactly what it is you are doing/trying to send
Another thing, why oh why when you have a contact linked to fb can you not have a button for go to fb page.... You have pics, messages etc, meh
Dont know as dont have FB but I see in the PEOPLE section, if you go into a contact, you go to "updates" (2 arrows in a circle design) and it shows you updates there. Be silly if they dont have a direct link to allow you to go to FB page.
am i reading this right you cant install apps to a microsd card by default?
Not yet, its meant to be coming in Android 2.2 (Froyo) which is due for release on May 19th. Not sure when Desire will get it tho.
right is rooting the phone relatively easy then? If i cant install stuff on my msd might aswell look at something else, also will Android 2.2 be a free upgrade?
I'd read that it was being worked on, but no plans to include it in Froyo. Have you got a link where it states it is going to be included in Froyo please?
Best "legit" source doesnt confirm a set date but does say VERY soon -
http://code.google.com/p/android/issues/detail?id=1151#c533
This comes from the Google Dev thats responsible for this issue. The status has been "Future Release" for a while now.
I have synced the contacts i actually want in my addy book with FB
Just wondering how you went about doing this? I've had to disable FB sync to stop loads of contacts appearing?
Got mine today, phones great but going to stick with my old phone... whats the going rate for these phones now?
