HTC desire case thread
**** me the first Desire case i ordered from HK still hasnt arrived and now people are getting these ones, which i also ordered too.
Emailed the guy and he said that the first case was shipped out and should be with me in a week or so..that was 2 weeks ago...not gonna bother with him, just going to log a very negative feedback.
Hopefully the one posted above ill get today hopefully...fingers crossed.
my case arrived today, it's been 28 days since I ordered it off their ebay store.
been using my htc touch hd case since I got the desire on 30th march, been having to take the phone out of the case as the sensor is covered so the phone screen is blanked when I make/recieve a call(and doesn't come on untill I take the phone out of the case).
Could you add a couple more pics of how the Gelaskin fits please?
What do you mean from the sides? Very easy to fit, can take it off and store it on some paper and use again at any time etc.
Also where did you get the Gelskin from?
Gelaskins website from Canada, about £12 iirc and just under a week to arrive.
@leoncc - what rubber protector is that on your htc?
Case-Mate Barely There
If your looking at one of those, best off going to the Zagg website, signup to their ipad comp and get a discount code upto 50%
Kimbie
Cool thanks but are they any good:confused: don't look like they will protect them from drop though and isn't the desire screen meant to be bullet proof?:confused:
Some pictures of the official HTC pouch, S520 I think. It's pretty good quality. It's a bit tight but will probably loosen once used a bit more. The pull tab works fine. For £11.95, it's a bit pricey for what it is.
Still prefer my android pouch, for £3.50.. you can't go wrong. :p
Though on my android pouch, the seams on the side aren't lined up properly. No biggie though, I'm just being picky. :)
